Aerial fitting...what's missing
ZimZimmer
Northern Ireland
Z3 2.2i Sport
Received grommet and awaiting the aerial to be delivered today.
I removed the grommet but by the looks of things something is missing as I can just see what looks like a cut wire.
Can anyone advise and maybe share a pic of what I need?
Sean d
Lincolnshire
Looks like the top of the aerial has been snapped off
Lee
Z4 Coupe 3.0si
Depending on model and year some have the washer fluid bottle there and some have the smog pump and in some cases like yours some people having nothing.
Perfectly normal :)
mrscalex
Swindon & Swansea
A secondhand aerial unit is going to cost about £60.
Another expensive commodity like the clear headlamps. Everyone wants them for the same reason you are experiencing.
ZimZimmer
Northern Ireland
Z3 2.2i Sport
Cheers for the info.
I'm assuming when my stubby aerial arrives that I won't be able to fit it as the part is broken. I don't really need it to work as I don't listen to the radio (it actually was working for some stations without an aerial) I just want to fit the stubby to make it look complete.
One way or another you need to do something as water will leak in otherwise mine was similar ended up removed it all fitted a grommet in the hole and been meaning to fix ever since
ZimZimmer
Northern Ireland
Z3 2.2i Sport
Yeah I've fitted the grommet...should have removed the perished one before I ordered a new grommet and aerial. Would have just gone down the deleted aerial cap route mentioned by hard top.
Now I've got the grommet and aerial I may as well get the part needed to finish the job properly.
I was meaning mine is blanked off altogether
