Hi, not long had my Z3 3.0 (used to have a Z4) and so far so good except today I decided to leave it running to get up to temp when I noticed coolant on the floor. Traced it to a trickle on expansion tank seal and nowhere else is obvious, it only does this when up to temp and presume this is when the pressure is at its peak.
Checked Oil and all clean and the coolant is Ok-ish with slight bit of discolouration and due a change.
I have attached some photos of the expansion tank leak and wondering if this is a known problem on the 3.0 expansion tank due to age (67K and 03 Plate)? Is it easy to swop out/change? Or is it the start of something else?
Thanks Alan
Thanks Alan
