Some owners have put in a Dab head unit or are thinking about it, just wondered what the advantages of Dab are over streaming Internet radio from your mobile phone?
I believe there's two kinds of screen aerial - Amplified and un-amplified. An amplified aerial should be much better. I'd expect those to work on something 1/10th the signal of an un-amplified one.I fitted a dab stereo in summer last year,with a windscreen Ariel which is temporarily stuck on top of the dash until I have a new screen fitted.
It's not as good as I expected but I'm putting it down to the temporary Arial position,when I drive into a valley the reception is awful and out in the country side not so good.
Hopefully when the new screen is fitted and I've moved the Ariel up the screen it will improve.
But I must say being able to just plug in a usb stick with my favourite tracks on is excellentand no more carrying CD's around....which is a bonus in a zed cus there's no where to store them
Steve
. Yes - life is too short.Hmm not sure if I have an amplified Ariel but it has two wire/connections on it,one to usual dab point and the other to a 12 volt feed,in the instructions it said that the 12 volt connection could be made by pushing it into the FM Ariel point on the back of the stereo,which is what i did.I believe there's two kinds of screen aerial - Amplified and un-amplified. An amplified aerial should be much better. I'd expect those to work on something 1/10th the signal of an un-amplified one.
Because the way DAB works, you either get a signal or you don't. You might get a garbled bit of up to a second occasionally. An amplified signal will give a better signal/noise ratio which helps the DAB tuner to recover the signal. Want a masterclass on how COFDOM encoding works? I guess not. Yes - life is too short.
When you say the valley - valley of death? valley of the dolls? or, some dark place in the wilds of Derbyshire?
Let me know and I'll see if I can get the coverage plots for that area. I should be able to tell you if you can expect to get a signal there.
FM radio waves (on which DAB is broadcast) propagate in straight lines. AM can follow the curvature of the earth.Hmm not sure if I have an amplified Ariel but it has two wire/connections on it,one to usual dab point and the other to a 12 volt feed,in the instructions it said that the 12 volt connection could be made by pushing it into the FM Ariel point on the back of the stereo,which is what i did.
The valley....i meant when you decent so you have hills either side of you,and yes in Derbyshire,Breadsall,Oakwood area.....does happen in other places too
Steve
Just looked - you're at the bottom of that great hill on the A38. You're served off Quarndon which is 125m high and virtually on your doorstep. That should get into all but the deepest valleys. As it is north east I though you shouldn't have a problem. I'll see if I can get the coverage plots.FM radio waves (on which DAB is broadcast) propagate in straight lines. AM can follow the curvature of the earth.
When you're in a valley, you may be on a shadow area. I'll take a look see which transmitter(s) cover there, what height they are and if they reach into that area. Also, we're installing some new ones in some parts of Derbyshire. You might be in luck.
Oooh lets hope so then Ian,fingers crossedFM radio waves (on which DAB is broadcast) propagate in straight lines. AM can follow the curvature of the earth.
There are over 250 different stations on DAB - these are spread right across the country. I was doing some data for each and everyone of them today!Oooh lets hope so then Ian,fingers crossed.
I forgot ti say in my previous post,the huge increase in choice of radio stations is another plus over FM.
Steve
Bloody hell no wonder you're always so busyThere are over 250 different stations on DAB - these are spread right across the country. I was doing some data for each and everyone of them today!
It looks pretty flat around there. I can only put your poor reception down to the antenna being flat across the windscreen rather than being vertical. Which station does it happen on? unlucky for you, the DAB should have gone on Drum Hill, but for some technical reason it was moved further over to Quarndon. If it isn't fixed down, just try and move to the edge of the screen and use some masking tape just to try if it improves things.Oooh lets hope so then Ian,fingers crossed.
Steve
Tbh it happens on all my pre set stations,it's got to be due to the ariel position in the car,as you said I should try moving it using masking tape to find a sweet spot.It looks pretty flat around there. I can only put your poor reception down to the antenna being flat across the windscreen rather than being vertical. Which station does it happen on? unlucky for you, the DAB should have gone on Drum Hill, but for some technical reason it was moved further over to Quarndon. If it isn't fixed down, just try and move to the edge of the screen and use some masking tape just to try if it improves things.
