Guys I want to change the Differential oil I have not done this before
so any hints / tips will be greatly received
Yes I used exactly the same Dave. Didn't realise you had a LSD
My tip... get the oil you want then take it and the Zed to your local friendly garage who has a ramp and will do the job for you for a drink. Saves the hassle of scrabbling about under the car and struggling with the drain/fill plugs. If you do DIY Barry undo the fill plug first. Then if you can't undo it and you've already drained the diff you're not stu**ed, and off the road. BOL.Guys I want to change the Differential oil I have not done this before
so any hints / tips will be greatly received![]()
Same as me then Dave25% I think Dave
That's what I did. He did it along with the gearbox oil.My tip... get the oil you want then take it and the Zed to your local friendly garage who has a ramp and will do the job for you for a drink. Saves the hassle of scrabbling about under the car and struggling with the drain/fill plugs. If you do DIY Barry undo the fill plug first. Then if you can't undo the drain plug you're not stu**ed, and off the road. BOL.
mmmm same here. I couldn't get the car up high enough (safely) so I went the local garage route. £10 to do both the diff & gearbox oil.That's what I did. He did it along with the gearbox oil.
