- Dec 7, 2020
- Location
- Plymouth
- Model of Z
- Z3 1.9 E36 M43 4 cylinder 118 HP 197 km/h 2001 - 2003
Just connected up a new scanner and got the following error codes:
1) F5 CAN bus ASC 1message not sent ( i did have an issue with another Connector - replacement works)
2) Voltage supply Terminal R faulty. The carly scanner says there is too much voltage coming out of the postive terminal.
Can you please explain what these codes mean please in simple english
Thanks
PS I have also the dreaded air bag code (70) but apparently quite common. So ordered a emulator.
Thanks
