Fractured Exhaust on a 2002 1.9
Synclare
Staffordshire
Having been out on a Sunday bimble in the zed I was aware of a blowing exhaust on my return, sounded like the downpipe to manifold joint so ordered a new gasket. Came to fit it a while later and realised on inspection that it was not the gasket but the pipe had actually split at the flange .I eventually took the exhaust off (a one piece genuine BMW system) and found not one but both pipes had fractured at the mounting flange. After some thought it became apparent that there should be some sort of bracing bracket to tie the exhaust to the engine/gearbox preventing relative flexing between the two. There was no such bracket when I fitted the replacement engine in the car (see newbie thread). As a result when the engine flexes on it's mounts it kept pulling on the exhaust downpipe which eventually worked on the downpipe mounting flange causing the fracture evident in the photo. It transpires the exhaust is stainless steel including the flange and required welding up by an outside welder as I have no provision for stainless welding. To prevent a recurrence I made a simple tie bar out of 1/8 inch steel plate and exhaust clamp, this was to brace the exhaust downpipe to the gearbox to stop the flexing on the downpipe joint. Clearly the original had rusted away and disappeared.
The tie bar fitted in the following picture:
Moral of this tale? check your tie bar is there!
Synclare
Staffordshire
Aah, so that is the sort of tie bar I should have had (athough mine is a single pipe) Thanks for sharing.
Having been out on a Sunday bimble in the zed I was aware of a blowing exhaust on my return, sounded like the downpipe to manifold joint so ordered a new gasket. Came to fit it a while later and realised on inspection that it was not the gasket but the pipe had actually split at the flange .I eventually took the exhaust off (a one piece genuine BMW system) and found not one but both pipes had fractured at the mounting flange. After some thought it became apparent that there should be some sort of bracing bracket to tie the exhaust to the engine/gearbox preventing relative flexing between the two. There was no such bracket when I fitted the replacement engine in the car (see newbie thread). As a result when the engine flexes on it's mounts it kept pulling on the exhaust downpipe which eventually worked on the downpipe mounting flange causing the fracture evident in the photo. It transpires the exhaust is stainless steel including the flange and required welding up by an outside welder as I have no provision for stainless welding. To prevent a recurrence I made a simple tie bar out of 1/8 inch steel plate and exhaust clamp, this was to brace the exhaust downpipe to the gearbox to stop the flexing on the downpipe joint. Clearly the original had rusted away and disappeared.View attachment 27153
The tie bar fitted in the following picture:View attachment 27154Moral of this tale? check your tie bar is there!
Adrian, you'll most likely find that when the exhaust was fitted the gearbox mounting was knackered and was simply discarded. You can get replacement ones easy enough, but that is common on 3 series cars which have "lost" that bar.
Synclare
Staffordshire
Thanks for that Tony, my fault I guess for not twigging when I fitted the replacement engine. Was surprised to find it a stainless system though
Hey mate, I don't know anyone who has a Crystal ball, do you? The stainless system is the bonus, the g/box mounting is peanuts.:thumbsup:
Synclare
Staffordshire
The zed I am breaking also has a BMW stainless exhaust which kinda suggests they were fitted from new? The emissions report on the mot showed virtually no emissions at all implying the cat is fine, @Grumpy would be well jealous!!
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
He bloody would! Can't get my emissions down for love nor money!
