Front turn signals not working
Marquisz3
North Carolina
V8 roadster
For context it’s done this since buying the car I’ve just been trying to tackle this, all of the rear and side turn signals work and flash just fine, I’ve replaced the bulbs as well as even the flasher relay but for some reason the headlight turn signals still don’t seem to work I’m thinking it could either be a connector issue or maybe a ground do they have their own specific ground aside from the normal daytime running light wire
Delk
Hemsby Norfolk
Z3 3.0T
Do they work when you press that hazzard button? They are fed through this and then each have thier own feed and ground after the switch.
Marquisz3
North Carolina
V8 roadster
Interesting I didn’t know that each one had its on ground I might have to splice it and reground it to test I’m assuming it’s the brown wire out of the 3? I don’t currently have a hazard switch as the old one was missing
Delk
Hemsby Norfolk
Z3 3.0T
Sorry. I had that wrong. Was busy at work and didnt look at the drawing well. The power feeds come from the hazzard relay and not the switch. You can chase the wires on the pdf to make life easier.
Marquisz3
North Carolina
V8 roadster
The hazard relay is the same as the turn signals relay isn’t it?
Marquisz3
North Carolina
V8 roadster
update messed around with it some more, i had to clean off the right side contacts to get it to work and the connector on the left side was brocken as i swapped over the new known good turn signal so just need a new connection to bulb
