TMC Motorsport
Hi all,
Need some help if possible please. The last time we raced the Zed at Donington it ran fine in qualifying, then when it came to the race it wouldnt rev above about 5k rpm. It also ran very hot, sticking at around 102 degrees.
The car now has no catalytic converters, no abs unit and no asc. All the wheel speed sensors are still connected, as is the sensor on the diff. We tried having it remapped as thought it might have been running lean, but that hasnt stopped it happening.
It also now has a digital dash board so the speedo feed is no longer connected. Could this have an effect?
It seems fine out of gear, and will happily rev to 6k when not under load (dont panic, we only did that briefly!) so this makes me think its a clutch or gearbox sensor?
Has anyone come across this? Any ideas? We're testing next weekend and racing at silverstone the week after so it needs to be sorted!
Many thanks in advance.
Matt
Matt
