Inner sills
D R Oldfield
Barrow-in-Furness
Hi does any one have any recommendations what is the best paint to paint the inner sills on my Z3? is it Hammerite or an epoxy based seam sealer
any thoughts ?
Jimbob_OD
Lancashire
1.9 M43
I did mine last month.
Cleaned the old corrosion off with a wire cup on an angle grinder, treated with Bilt Hamber Hydrate-80 followed by a coat of zinc primer.
Then covered the inner sills and the inside of the new outer sills in loads of waxoyl before putting back together.
petecossie
Teesside
Z3 M Coupe
I did mine 4 years ago, removed rust with polycarbide disc (from Screwfix) then used Bilt Hamber for surface treatment followed up with Hammerite primer then about 3 coats of Hammerite smooth black. Then to finish off my paint guy injected Waxoyl in cavities.
Before
After
The sill covers were also treated with Waxoyl on inside.
All good for a good few years I'm sure.
