Hi guys, reference the picture below. The air consumption is 0 with the car idling? its a 2.2 Z3.
I'm pretty sure there should be a value there. Is this indicative of a bad MAF sensor? I'm trying to diagnose some weird symptoms I have. When driving, I have excessive smoke coming out of the exhaust. My CCV is shot anyway so I'm replacing that, as well as throttle body gasket, intake boots, DISA O-ring. I have just replaced all the VANOS seals and the Rocker cover gasket. This issue only started when the rocker cover and VANOS seals were replaced though. I accidentally snapped the breather pipe taking the rocker cover off so that's why I'm replacing the whole CCV.
Now I know white smoke out of the exhaust is usually a HG fail, but it doesn't smell of burning coolant. And like I said it was running fine beforehand. I have 4 brand new Lambda sensors to fit too as I'm not sure when they were replaced and I'd rather fit new ones now and get it over and done with.
Any help would be appreciated.
