Thanks for responses.
I'm a try and do it right merchant as I hope people will know. But on this occasion it was appropriate to look at doing an interim job on the trailing arms in situ to get the car through the MOT with no advisories. Then tackling things properly later. Normally I get everything blasted and coated. However as is usually the case with me I ended up saying in for a penny and dropped the whole lot in the end. So off to the blasters they go.
Can you tell me more about the zinc plating
@Lee? Obviously an extra anti-corrosion step. But presumably this is done with immersion/electrolysis rather than a specialised preliminary powder coating? Thanks.
