My rear beam brackets (or push rods as BMW call them) are rusty and holey so I’ve got some replacements on the way.
I thought I’d be a good Boy Scout and be prepared for the swap by getting all the fixings loosened off.
The main 22mm nuts were fine, good clean of the threads and lots of Plus Gas, worked them back and forward and got them off, cleaned up and refitted.
Cleaned up the 2 6mm Allen head bolts either side, used a needle to clean out the Allen sockets and again lots of Plus Gas.
First one came out nicely once I had tapped the Allen socket firmly home and given it a steady, firm pull. The one next to it and the other two are a different story!
All 3 show signs of having been previously rounded out and the 6mm was baggy in them. Didn’t even try loading it. Tried tapping a Torx in but that span on gentle pressure on all 3. What next? I’ve ordered a set of Unwin bolt extractors but I’m worried that the tapered base of them will mean they won’t work. I’m extra worried about the two next to the fuel tank as access is a bi*** and I don’t want to use heat there...
No access to welding equipment and they are both so crusty and weak I’m concerned about driving it anywhere...
