Hi Paige
Sounds like you are in for a new left trailing arm.
To do the replacement, the mechanic needs to drop the whole subframe. Its not a big job if you have done it before. A couple of hours. Best that you replace the trailing arm bushings and sub-frame bushings on both sides while you have it all out.
The last time I did the job the bushings costs where:
- NZ$80 for 2 sets of trailing arm bushings.
- US$35 each for the sub-frame bushings. Yes I get my parts from a mix of places locally and internationally.
Some People go and fit poly Sub-frame bushings. I have these on my 3.0L Z3 because the rear sub-frame failure problem affects the larger sized motor Z3 more. I fitted rubber sub-frame bushings to my 2.0L Z3 (low risk of sub-frame failure) and I like the ride more than the 3.0L Z3. Its softer and smoother.
Like when you did your diff rebuild. Put the last 7 digit of your VIN number into the search tool at
www.RealOEM.com and search for the part numbers for the left trailing arm and the half shaft for your car. You may need your build spec (decode) again to see what diff option you have. This impacts on the haft shaft as you will likely see notes about a 25% diff option.
If you are buying a new trailing arm, then you don't need the half shaft part number. The mechanic will fit your existing half shaft into the trailing arm. This may require a new wheel bearing and seals.
If you are buying a second hand trailing arm, then knowing the half shaft part number will be useful. Most second hand trailing arms come with a half shaft fitted. There are several different half shafts that go with your trailing arm to allow for different engine sizes and differential sizes. If the parts supplier can tell you what car the trailing arm came off, or the half shaft part number, then you'll know if you/mechanic needs to change the half shaft or not.
Hope this is making sense.
Murray
