Replacement Bushes - options?
CaptainCarNose
Just recently had the track rod end swapped as it had disintegrated, that has massively improved the handling and feel of the car but the mechanic did say that all the bushes are completely shot. He did a 4 wheel alignment but the back was out slightly - he said that whilst there is no adjustment possible, a new set will probably correct it.
Just wondering which bushes / mounts etc. I should get swapped and the best products to go for. I just want an OEM feel, nothing overly hard. Obviously I could order BMW parts but there might be a better / more cost effective option?
Thanks,
This will give you an idea .
If the rear is out pretty much guaranteed wear in most of the rear bushes if original.
Really needs a rear end rebuild top put proper right .
Depends on where you are @Lee could be your man .
If you go to forums and go to
zedshed hq you will be able to see the stuff they do .
Stephen :)
  • Thank You!
Reactions: Lee
