my 2000 Z3 2.3 with 34,000 miles is is showing fault code 17 - sensor side airbag right. I have removed the seat 3 times: find no water, corrosion or disconnect. Any ideas? Is the airbag system inoperable with this code/light on?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
