Hello all! Hope you are well!
After months of tidying out the garage to make way for the Z3 restoration, I've finally started stripping her down... I starting to realise where alot of my free time is going to be spent.
So far we've removed upper and lower intake, fan housing and radiator, wiring loom, belts and tensioners, thermostat, water pump, amongst other things.
Almost every intake and vacuum hose is split / not even connected. Injectors are yukky. Signs of neglect everywhere.
I this morning removed the valve cover to find old, sludgy oil inside the cover and some surface rust on the upper most cam lobe. The car had been sat for about 5 years before I acquired it. Could this be caused by condensation inside the cover over that period of time?
Another thing I noticed is that some of the cam lobes have been wearing down on the side of the lobe more than others, if you know what i mean? Is this down to natural wear and tear, or maybe an oil starvation issue?
I have checked the "squirters" inside the valve cover and although rather sludgy, the aren't actually clogged up.
I also have a leak coming down from the gearbox
its going to be coming out anyway as she needs a clutch...
Would be delighted to hear everyones opinion on the state of the cam. 2nd hand ones seem fairly inexpensive, and would much rather have her all sorted while shes apart.
Thanks in advance everyone
