The susceptibility of the Z3 to tramlining and bump-induced suspension deflection is well documented, as are methods of improving the handling (mainly focussed on replacing the suspension bushes with solid rubber or poly).
As I understand it 17*" wheels are more susceptible than other sizes, and in my case a 1997 1.9 with 7.5x17" standard BMW wheels with 225/45 R17 tyres and standard suspension handling was considerably improved after fitting poly bushes, and raising tyre pressures to 2.5 bar resulted in further improvement - albeit at the expense of ride quality and probably tyre wear.
However, the relative susceptibility of the 17" wheels versus the rest intrigues me, and I note that the wheel offsets are as follows irrespective of rim width - 15" = 47mm, 16" = 46mm, 17" = 41mm. I have searched the threads for discussions on offsets and wheel spacers but they all seem to be more concerned with car/wheel appearance than handling. I assume offset is related to suspension geometry so my question is, would adding a 5mm spacer to bring the 17" offset to more closely match the others result in any noticeable difference to handling? - has anyone tried such (relatively) thin spacers? How do the larger offsets/thicker spacers discussed in many of the forums affect handling/steering effort etc.?
