Fuel trims. I think i know the answer but ..
Sajk
Hi all,
M52tu 2.8. M54 3.0 intake. CatCams 24lb VAC injectors. Tune from Active Autowerke.
Occasionally I get a non confirmed code for Bank 2 fuel trim exceeded buy never get an engine light. Today I decided to look at the trims when driving and accelerating.
SFT bank 2 is noticeably negative and under hard acceleration hits negative 19 which is huge.
It also suffers from an occasionally unstable idle where you can feel the occasional miss fire.
I suspect one of the injectors in bank 2 is dodgy OR the o2 sensor for bank 2 is bad but it does cycle quite well looking at the live data.
Ant thoughts and any suggestions on new 24lb injectors that don't cost 220 usd each like bmw ones.
I am running a tune from Active Autowerke in the states. One bank being rich I don't think points to a tune issue? Not sure.
I would look at the lamba's and see what the voltages are and if they're reading ok. If they've never been replaced I would get a new set installed, alot cheaper than new injectors. Alternatively send your injectors away for cleaning and testing.
I will look at the voltages again. I did check and they seem to be cycling between rich and lean on both banks at the same rate.
Back
