Tight/loose feeling will be a UJ seizing on one cross pin.Mine is a on/off heavy/light situation. It's more the noise that's annoying, squeek / spring crunching noise.
I'm pretty sure every where along the coloum has dried out.
SNAP. I’ve just been to Halfords for the same. I’ll report back in 10!Just been out to Halfords and got a can of WD40 White Lithium spay grease.
In the car park applied to top and bottom UJ's. Wow, instant improvement.
Now just have a slight squeek behind the wheel, took the cowling off and applied where i could, still squeeking a little
but only when steering to the left ??!!
I know i have a slight worn ball joint on the front right, have been told by my indy that it's nothing to worry about.
I'll get them to check again when i have the front bush's done.
Top tipping everyone![]()
Literally sprayed grease all around the area and there’s a noticeable improvement. Still feels heavy, but I do have a gravelled drive and wheels were on the ground.SNAP. I’ve just been to Halfords for the same. I’ll report back in 10!
Connor.
Are you sure that's not the person twirling the wheel?Now just have a slight squeek behind the wheel...![]()
Might be a silly question Connor, but have you checked the power steering oil level?Been back out in the car this evening. steering is still sticky/heavy. Tyre pressures adjusted to slightly higher values and still no better.
I think tomorrow I’ll get both wheels off the floor and test as mentioned. It might also be worth test fitting my old wheels (not winter tyres) also.
Connor.
I always jack under the front subframe or axle carrier at the rear. Then put axle stands on the jacking points.I need to test this. However I am not sure how best to raise both sides off the ground simultaneously without buying another trolley jack...
I was considering using the scissor jack but not too sure on the safety of using that and the trolley jack at the same time.
Connor.
I've just been thinking that I've never actually checked my steering column so I'm quite keen to do that now.People say that they don't like the "Electric" steering on the Z4 Steve, I have absolutely no issue with it. It is different but I've got used to it and now it's just "normal"
I was going to do mine this morning but couldn't get anywhere near the UJs. I'm assuming there's more room beside the 1.9 lump than the 6 pots?Just been out to Halfords and got a can of WD40 White Lithium spray grease.
You can get to the exposed bits on the straight 6’s but not near enough to get inside the gaitors.I was going to do mine this morning but couldn't get anywhere near the UJs. I'm assuming there's more room beside the 1.9 lump than the 6 pots?
Thanks for this Tony,I do it this way Connor. Run a front wheel onto a block of wood or a brick to raise the car up, then you can get your jack under the front lower arm rear mounting point. Jack the car up and place a stand under the jacking point. Repeat at the other side. Just remember to place the block/brick under the last front wheel before lowering.
Well that’s the thing Tony, the oil is the colour of the new fluid, it’s only when I lightly scraped the bottom of the reservoir it was black. If I test for the mechanical steering issues by raising the car and doing as you suggested, and all seems OK, do you think changing the reservoir is a good staring point?Black power steering oil points towards a failing pump mate. You can get a "flushing agent" for power steering systems, which might be worth trying in it then drain it an refill with new fluid.
