……… it’s been a long time coming………but
I have my Aircon WORKING!
Took it back to LRS at Sutterton ( more impressed with them each time I go): they did an OFN Nitrogen pressure test first for 10-15 minutes, purged it, and re-gassed it (apparently Z3s have an unusually large quantity of coolant) and checked it worked well.
Only fly in the ointment is my Aircon fan is not kicking in, so I have some electrical circuit testing to do to see why?
This b****y fan has caused me SO much aggravation
Grrrr!!!
After a quick cuppa, a methodical plan is coming together for testing the electrics:
Apply 12v to the fan plug to test the fan
( Edit : It works : both slow and fast)
1. Now that the Aircon system is pressurised switching it on should start the fan running, so a simple voltage test across the loom’s fan plug should show if the circuit is working to that point.
2. If that fails, the temperature sensor in the radiator should kick the fan in to both high and low speeds, so again I can test for voltage at the loom’s fan socket.
3. If both 1 and 2 fail I’ll have to check fuses and relays which could prove time consuming!
Electrics are not my strong point
