E85 brake calipers have a different brake piston though, it's larger in diameter so I'm not sure if there isn't a negative effect on the braking system under certain circumstances.Not strictly true. E85 Z4 rear callipers fit, but, when on the bleed screws are at the bottom, so you have to bleed them before you bolt them onto the carriers. Much less expensive too.
