Its the problem...(a tap from cig lighter to the blue/white 'power' wire on harness), but all it seems to be doing now is shorting fuses like window wipers/jets!
Post #16If you go to the first page of this thread there is a diagram that someone had put up and a picture of the stereo/wiring
So the red wire should be the "switched" live wire to turn the unit on/off and the yellow wire should be the "permanent" live to store the settings.
Best of luck Andy...Ok well ill have an attempt at this one later tonight then! I think if this one fails i will just have to pay a leccy to look at it and sort cos id be all out of options and probably patience too lol
