Here you go
@Andy McDonnell , from today's first hand experience. A guy brought in his BMW this morning, on which my colleague (the Ape man) fitted some parking brake shoes last July. Anyway the hold own spring for the N/S shoes has come adrift allowing them to catch on the drum. So, here's my tool for easy fitting of the hold down spring and pin.
The remains of the original pin and spring ( it didn't fall off just today , did it?)
This the tool I use for these pins, it was originally bought for removing the last 2 bolts from VW sumps against the flywheel end (such as on a Galaxy). The socket end is 3/8"
I f you don't have this you can do this with a 5mm Allen key, gives much better control. You can use this through one of the wheel bolt holes to aid the pin fitting.
If you need to clean out the holes for the slider pins, this is what you need, a home made tool for the cordless drill we all have these days. Took me about 15 mins. to make. A 4" 8mm bolt split down the middle with a hacksaw or grinding disc(carefully)
Wrap which ever grade emery strip around the bolt in the opposite direction of drill rotation, but allow 1/2" or so to protrude through the sot as this will add grip to the emery when it getting short.
View attachment 25279 View attachment 25277
The battery terminal cover is just to stop the emery strip unravelling.
Hope you might find this useful.
