We heli coiled Jues injector on the Sorento. It's got to be worth a shot but it still leaves what sounds like a ring problen underneath to address.
I agree @Zeti and with a screwed up plug thread he'll need either to switch heads or recondition this one. Personally I'd take the second head in, if it checks out good fine, if not refurb that one. Then @Faheem can still use the car till that's done and may not need to buy another car if all the parts are ready and he can get them installed. But he must address the ring problem first and may be better off transplanting engines if the spare car is okay. If not used 1.9's are pretty cheap! This would also offer Faheem the chance to rebuild the original engine for the experience and keep his car number matching!! JIMIt's a ring problem. Valves are OK. While hot , the dilatation of the pistons offer good sealing.
Though ATF provides pressure and supply drive from the torque convertor in auto and some semi gearboxes it is at the end of the day basically a lubricant and lubes an auto box.I have just got an email back from Opie oils saying they recommend a ATF ?
Either Redline D 4 or Fuchs ATF 5005? Cheaper alternative would suffice.
ATF in a manual gearbox now iam confused can any help advise please.
My cars a 1.9 1997
Tracy.
